/ALE/MAT
Block Format Keyword Compute material flow with ALE framework.
/ALE/MAT/mat_ID
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
Example (Air - Water)
#RADIOSS STARTER
#-  1. MATERIALS:
/UNIT/1
unit for mat
                   g                  mm                  ms
/MAT/LAW37/1/1
air (unit g_mm_ms)
#                Psh
                   0
#             RHO_l0                 C_l             ALPHA_l                NU_l            NU_VOL_l
                .001                2089                   0            1.787e-3                   0
#             RHO_G0               GAMMA                  P0                NU_g            NU_VOL_g
             1.22E-6                 1.4                  .1             1.48e-2
/ALE/MAT/1
/MAT/LAW37/2/1
water (unit g_mm_ms)
#                Psh
                   0
                .001                2089                   1            1.787e-3                   0
/ALE/MAT/2
#enddata
  1. There is no convection through a boundary face.
  2. With a collocated scheme (/MAT/LAW151 (MULTIFLUID)) there is by default a slipping wall boundary condition ( υ n n = υ w a l l n MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqipu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyXdu3aaS baaSqaaiaad6gaaeqaaOGaeyyXICTaaCOBaiabg2da9iabew8a1naa BaaaleaacaWG3bGaamyyaiaadYgacaWGSbaabeaakiabgwSixlaah6 gaaaa@460F@ ).
  3. With a staggered scheme (all material laws, except /MAT/LAW151) velocity must be fixed with /BCS option at boundary nodes. You can define either a solid wall boundary condition ( υ f = υ w a l l MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqipu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyXdu3aaS baaSqaaiaadAgaaeqaaOGaeyypa0JaeqyXdu3aaSbaaSqaaiaadEha caWGHbGaamiBaiaadYgaaeqaaaaa@3F7B@ ) or a slipping wall boundary condition ( υ f n = υ w a l l n MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqipu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyXdu3aaS baaSqaaiaadAgaaeqaaOGaeyyXICTaaCOBaiabg2da9iabew8a1naa BaaaleaacaWG3bGaamyyaiaadYgacaWGSbaabeaakiabgwSixlaah6 gaaaa@4607@ ).
  4. To define outlet/inlet, refer to /EBCS (or material boundaries: /MAT/LAW11 (BOUND), /MAT/LAW51 (MULTIMAT)).
  5. Contrary to Eulerian framework, a grid formulation must be used. By default, DONEA formulation is enabled (/ALE/GRID/DONEA).
