/ALE/OFF
Engine Keyword Deactivates the ALE / EULER parts that are listed.
/ALE/OFF
part_ID1
part_ID2
part_IDN
Definition
part_ID1
part_ID2
part_IDN
Part IDs of parts to be deactivated.
Only one part can be listed, per line.
  1. By default, all parts are active.
  2. The ALE calculation for the listed parts can be turned off which saves computation time, when using this option.
  3. Parts can be reactivated in a new Engine file by using /ALE/ON for the specified IDs.
