Engine Keyword This option defines the numerical method for internal force integration. This is relevant
only for brick element and the ALE legacy solver (momentum equation solved with
FEM).
/ALE/SOLVER/FINT/Iform
Definition
Field |
Contents |
SI Unit
Example |
Iform |
Integration method
(internal force for brick elements) flag.
- = 0
- Set to 3.
- = 1
- Volume integration of the stress tensor using a
shape function.
- = 2
- Surface integration for the hydrostatic stress
tensor only.
- = 3 (Default)
- Surface integration for the stress tensor.
(Real)
- Momentum equation has
local form:
(1)
Iform is a flag defining the numerical method to
compute
when integrated over the cell with
legacy solver (nodal velocities).
- Iform=1
- Was the default method up to Radioss version 2019.
- Iform=2
- The integration method used with obsolete card /CAA (Obsolete)
- Iform=3
- The integration method used as of Radioss version 2020.
For volume integration, shape functions are used to compute
at node, N:
(2)
Where,
The value
is taken at the integration point. It is
assumed that:
(3)
This assumption is exact for parallelepipedic
shape only, which is why the new default value method is set to surface
integration (Iform=3).
