/ANIM/GPS2
Engine Keyword Generates animation files containing volume based averaged GPS data, which is done by the relative element volumes (connected to same node use Vi/V total).
/ANIM/GPS2/Keyword3
Definition
Keyword3 GPS data type:
P
Pressure
VONM
von Mises stress
SIGX
Stress XX
SIGY
Stress YY
SIGZ
Stress ZZ
SIGXY
Shear XY
SIGYZ
Shear YZ
SIGZX
Shear ZX
TENS
All six stress components listed above
SHELL/UPPER
Six stress components at upper layer of shell element
SHELL/LOWER
Six stress components at lower layer of shell element
  1. /ANIM/GPS2 works only with constant stress element (8 node brick element with one point integration and TETRA4).
  2. The stress of corner node is extrapolated from stress at integration point.
