/ANIM/LSENSOR
Engine Keyword Write additional animation files (Animation Output File (A-File)) when a sensor in the list is activated.
/ANIM/LSENSOR
sens_ID1 sens_ID2 sens_IDN
Definition
sens_ID1, sens_ID2, sens_IDN | List of sensor ID's |
- The additional animation files are written in addition to classical animation files (/ANIM/DT) and in addition to animation files written by /ANIM/SENSOR.
- Animation files are written each time a sensor in the list is activated. For more explanation, see /SENSOR.
