/ANIM/SHELL/IDPLY
Engine Keyword Generates animation files containing integer value, defining if a shell belong to a given ply.
/ANIM/SHELL/IDPLY/Keyword4
Definition
Keyword4 | Ply output. 2
- The contour animation results
can be interpreted as:
- Animation Result Value
- Description
- 0
- Shell does not belong to ply
- 1
- Shell belongs to ply
- -1
- Shell belongs to ply, and has failed
- Ply ID number is prop_ID from /PROP/TYPE19 (PLY)/prop_ID or ply_ID from /PLY/ply_ID.
