/ANIM/SHELL/IDPLY/Restype
Engine Keyword Generates animation files containing shell tensor data for shell elements that use ply based composite properties, /PROP/STACK (TYPE17), /PROP/TYPE51, or /PCOMPP.
/ANIM/SHELL/IDPLY/Restype/Keyword5/Keyword6
Definition
Restype Output tensor: 1 2
STRESS
Stress tensor
STRAIN
Strain tensor 3
EPSDOT
Strain rate tensor
Keyword5 Ply output. 4
I
Ply ID number. Integration point Keyword6 must also be entered.
ALL
All the integration point results of all the plies are output.
Keyword6 Output location: Only used if Keyword5 is entered.
J
j’th integration point of ply I.
  1. Stress and strain tensor are output in the elemental coordinate system.
  2. For fully integrated BATOZ shells, Ishell=12, the output value is the average of the in-plane Gauss points.
  3. Strain tensor is output only if Istrain =1 in shell property for material law numbers < /MAT/LAW25 (COMPSH), except laws /MAT/LAW15 (CHANG) and /MAT/LAW19 (FABRI). For all other material laws, the value of Istrain does not matter.
  4. Ply ID number is prop_ID from /PROP/TYPE19 (PLY)/prop_ID or ply_ID from /PLY/ply_ID.
