/ANIM/SHELL/NXTFACTOR
Engine Keyword Generates animation files containing the instability factor of NXT failure model as function of a shell element integration point.
/ANIM/SHELL/NXTFACTOR/Keyword4
Definition
Keyword4 Output location.
N
Layer number N
UPPER
Upper layer
LOWER
Lower layer (number of integration point is equal to one)
ALL
All the layers
  1. In case of BATOZ shell element, the value is the average value of the Gauss points in the layer.
