/ANIM/VERS
Block Format Keyword Defines the animation file version.
/ANIM/VERS
Anim_vers
Definition
Anim_vers Format of Radioss Starter Animation File
Default = 44 (Integer)
  1. For options requesting it, an Animation File can be written by the Radioss Starter. For an example, refer to /FXBODY.
