*DAMPING_GLOBAL
LS-DYNA Input Interface KeywordUsed to define the Rayleigh mass and stiffness damping coefficients for the entire model.
(1) (2) (3) (4) (5) (6) (7) (8)
*DAMPING_GLOBAL
  Alpha Scale_X Scale_Y Scale_Z Scale_XX Scale_YY Scale_ZZ
Definition
Alpha Mass damping coefficient.
(Real)
[ 1 s ]
Scale_X Scale factor for translational degree of freedom (DOF) in X direction.
(Real)
Scale_Y Scale factor for translational degree of freedom (DOF) in Y direction.
(Real)
Scale_Z Scale factor for translational degree of freedom (DOF) in Z direction.
(Real)
Scale_XX Scale factor for rotation degree of freedom (DOF) in X direction.
(Real)
Scale_YY Scale factor for rotation degree of freedom (DOF) in Y direction.
(Real)
Scale_ZZ Scale factor for rotation degree of freedom (DOF) in Z direction.
(Real)
  1. This keyword maps to /DAMP.
  2. If all scale factors are zero, the Alpha value is set in all directions.
