/DEFAULT/INTER/TYPE19
Block Format Keyword Defines default values for TYPE19 interfaces.
Blank
    Istf   Igap Iedge Ibag Idel
Blank
                Irem_gap Irem_i2
Required Fields
Blank
      Inacti
      Iform
Definition
Istf Stiffness definition flag. 9
= 0
Set to 1000.
= 1
Interface stiffness is entered as Stfac.
=2
Interface stiffness is the average of the main and secondary stiffness.
=3
Interface stiffness is the maximum of the main and secondary stiffness.
=4
Interface stiffness is the minimum of the main and secondary stiffness.
=5
Interface stiffness is the main and secondary stiffness in series.
= 1000 (Default)
For node to surface contact, interface stiffness is only based on main stiffnes.
For edge to edge contact, interface stiffness is the main and secondary stiffness in series.
(Integer)
Igap Gap/element option flag.
= 0
Set to 1000
= 1
Gap varies accordingly to the characteristics of the impacted main surface and the impacting secondary node.
= 3
Variable gap + gap scale correction of the computed gap + size of the mesh is taken into account to avoid initial penetrations.
= 4
Node to surface contact uses variable gap + gap scale correction of the computed gap + deactivation of neighbor secondary nodes, if element size < gap. Edge contact uses a constant contact gap, Gapmin.
= 1000 (Default)
Gap is constant and equal to the minimum gap.
(Integer)
Iedge Edge to edge contact flag. 24
= 0
Set to 2.
= 1
Only external edges of defined surfaces are generated.
= 2 (Default)
All segment edges of defined surfaces are generated.
(Integer)
Ibag Airbag vent holes closure flag in case of contact.
= 0
Set to 2.
= 1
Closure.
= 2 (Default)
No closure.
(Integer)
Idel Node and segment deletion flag. 6
= 0
Set to 1000.
= 1
When all the elements (4-node shells, 3-node shells, solids) associated to one segment are deleted, the segment is removed from the main side of the interface. It is also removed in case of explicit deletion using Radioss Engine keyword /DEL in the Engine file.
Additionally, non-connected nodes are removed from the secondary side of the interface.
= 2
When a 4-node shell, a 3-node shell or a solid element is deleted, the corresponding segment is removed from the main side of the interface. It is also removed in case of explicit deletion using Radioss Engine keyword /DEL in the Engine file.
= 1000 (Default)
No deletion.
= -1
Same as =1, except non-connected nodes are not removed from the secondary side of the interface.
= -2
Same as =2, except non-connected nodes are not removed from the secondary side of the interface.
(Integer)
Irem_gap Flag for deactivating secondary nodes, if element size < gap value, in case of self-impact contact.
= 0
Set to 1.
= 1 (Default)
No deactivation of secondary nodes.
= 2
Deactivation of secondary nodes.
(Integer)
Irem_i2 Flag for deactivating the secondary node, if the same contact pair (nodes) has been defined in /INTER/TYPE2.
= 0
Set to 1, if /IMPLICIT is defined.
Set to 3 for explicit solution.
= 1 (default for implicit solution, if /IMPLICIT is defined)
Secondary nodes in /INTER/TYPE2 tied contacts are removed from this contact.
= 3 (default for explicit solution)
No change to secondary nodes.
(Integer)
Inacti Deactivation flag of stiffness in case of initial penetrations. 19
= 0
Set to 1000
= 1
Deactivation of stiffness on nodes
= 2
Deactivation of stiffness on elements
= 3
Change node coordinates to avoid initial penetrations
= 5
Gap is variable with time and initial gap is computed as:
g a p 0 = G a p P 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaiaadg gacaWGWbWaaSbaaSqaaiaaicdaaeqaaOGaeyypa0Jaam4raiaadgga caWGWbGaeyOeI0IaamiuamaaBaaaleaacaaIWaaabeaaaaa@4003@ where, P 0 is the initial penetration.
= 6
Gap is variable with time, but initial penetration is computed as (the node is slightly depenetrated):
g a p 0 = G a p P 0 5 % ( G a p P 0 ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaiaadg gacaWGWbWaaSbaaSqaaiaaicdaaeqaaOGaeyypa0Jaam4raiaadgga caWGWbGaeyOeI0IaamiuamaaBaaaleaacaaIWaaabeaakiabgkHiTi aaiwdacaGGLaGaeyyXICTaaiikaiaadEeacaWGHbGaamiCaiabgkHi TiaadcfadaWgaaWcbaGaaGimaaqabaGccaGGPaaaaa@4B5E@
= 1000 (Default)
No action.
(Integer)
Iform Friction penalty formulation type.
= 0
Set to 1.
= 1 (Default)
Viscous (total) formulation.
= 2
Stiffness (incremental) formulation.
(Integer)
