/DT/NODA/Keyword3/Iflag
Engine Keyword Activates the nodal time step control method with the option to apply mass scaling to increase a model’s time step.
Δ T sca Δ T min initial_mass_ratio
If Iflag=1, insert the next line
grnd_ID
Definition
Keyword3 Time step control type. 1
CST
Use default constant time step method, /DT/NODA/CST2. 5 6
CST1
Nodal mass is increased to maintain a constant time step Δ T min . 56
Recommend Δ T sca =0.67.
CST2
Nodal mass is increased to maintain the constant time step Δ T min . Improved formulation. 56
SET
Reduce the equivalent nodal stiffness to maintain the constant time step, Δ T min
STOP
At the start of the simulation, the initial nodal mass is increased using initial_mass_ratio to determine an initial time step. No additional mass is added during the simulation. If the time step reaches Δ T min , the simulation stops and a restart file will be written.
If Keyword3 is not specified, as in /DT/NODA/Iflag, then the computation will use the nodal time step and Δ T min is not used.
Iflag Node group flag.
=0 or blank
All nodes use the nodal time step method.
=1
The nodal time step method is only applied to the nodes in node group grnd_ID.
Δ T sca Scale factor on critical nodal time step.
Default = 0.9
Δ T min Minimum time step.
initial_mass_ratio Mass ratio increase at the beginning of the computation used to increase the minimum time step. This value is entered as a ratio, so a 5% increase in mass would be entered as 0.05.
Default = blank
grnd_ID The nodal time step method is only applied to the nodes in this node group, read only if Iflag=1.
  1. For all Keyword3 options, the time step control will be activated when the time step of the node controlling the time step of the simulation becomes less than the defined timestep divided by Δ T sca .
  2. Only one /DT/NODA/Keyword3 option can be used in a simulation.
  3. When using Nodal time step, the computation of each cycle is slightly more expensive but the time step can be higher especially for low quality meshes.
  4. When /DT/NODA/Iflag is used (without Keyword3), the computation will use the nodal time step method, and Δ T min and initial_mass_ratio are not used.
  5. For constant nodal time step options, (Keyword3=CST, CST1, and CST2), the time step used at the beginning of the simulation is the maximum of Δ T min or, time step calculated with mass added by initial_mass_ratio. The initial time step will then be maintained during the simulation by adding additional mass, if needed.
    /DT/NODA/CST
    0 Δ T min
    The computation is done with minimal nodal time step of Δ T min value. Mass will be added to maintain this timestep.
    /DT/NODA/CST
    0 Δ T min 0
    Radioss calculates a nodal time step to give 0% of initial mass increase and uses the maximum value of this calculated time step and Δ T min .
  6. The time step for different amounts of percent mass increase information is printed as a table and a graph in the Starter output file.
  7. /DT/NODA/Keyword3 is compatible with all options of /DT/Eltyp/Keyword3.
  8. /DT/NODA and /DT/NODA/CST* are compatible with /DT/INTER/AMS from version 2017.2.3.
  9. /DT/NODA/CST* is compatible with advanced mass scaling, /DT/AMS. If used with /DT/AMS, AMS will be applied to the part group defined in Starter /AMS card and /DT/NODA/CST* applied to nodes not belonging to the AMS part group.
    For example:
    • /DT/AMS/1
    • Δ T sca1 Δ T min1
    • Tol_AMS
    • /DT/NODA/CST
    • Δ T sca1 Δ T min1
    This is even advised in order to minimize computing time in models where AMS only applies to selected parts.
    Note: It is pointless to use a higher time step in AMS than the one used in classic mass scaling since the smaller time step limits the performance.
