/DYNAIN/DT
Engine Keyword Define time output frequency and parts to be written to the state file.
/DYNAIN/DT/Keyword3
Tstart Tfreq
part_ID1 ... part_IDN
Definition
Data | Description | SI Unit Example |
Keyword3 | Part selection method.
Tstart | Start time. | |
Tfreq | Time frequency. | |
part_ID1 ... part_IDN | If Keyword3 is blank, required list of parts whose state output is written to the state file. |
- Writes initial state files in LS-DYNA format (.dynain) at a time frequency equal to Tfreq, the first file being written at time Tstart.
- The state file name is
Runname_nnn#.dynain.Where,
- Runname
- Run Name (/RUN).
- nnn#
- File number (four digits) from 0001 to 9999.
- Each dynain file contains:
- *NODE block defining nodes IDs and actual coordinates of the corresponding nodes
- *ELEMENT_SHELL_THICKNESS block defining shell IDs, connectivity of shells and thicknesses
- The state output fields (stresses, strains ...) ask for output into the state files to be written only for the elements belonging to those parts ID requested or if Keyword3=ALL for all parts.
- It is recommended to use /DYNAIN/SHELL/STRESS/FULL and /DYNAIN/SHELL/STRAIN/FULL for being able to completely restore the state of shell elements.
