/DYREL/1
Engine Keyword Dynamic relaxation applied to node group identifier grnd_ID.
/DYREL/1
grnd_ID
T
Definition
grnd_ID | Node group identifier. | |
Relaxation
factor. Default = 1.0 |
T | Period to be damped. with |
- Can be used only if Starter Input uses Block Format.
