Block Format Keyword In this group, keywords are used to set default value, global parameter, analysis type, input/output print,
damping and ALE and CFD treatment for the whole model. For default value, it is still possible to overwrite in each
specific keywords.
Block Format Keyword In this group, keywords are used to combine material and property information (/PART), assemble model (/SUBSET) or define a separate model (//SUBMODEL).
Block Format Keyword Interfaces solve the contact and impact conditions between two parts of a model. Several interface types are available
in Radioss and use different contact treatments.
Block Format Keyword Radioss supports several different kinematic constraints, which are mainly used to impose acceleration, velocity, displacement
or temperature in structure or constraint the moving of structure. They are mutually exclusive for each degree-of-freedom
(DOF). Two kinematic conditions applied to the same node may be incompatible.
Block Format Keyword In Radioss the following load cases are available. Stress/strain as initial state could be considered by modeling, as well as
pressure, gravity, and thermal load.
Block Format Keyword Adaptive Meshing is used in metal forming to divide the element to better describe the geometry. /ADMESH/GLOBAL and /ADMESH/SET are not available for SPMD computation.
Block Format Keyword Describes the ideal gas equation of state for stiffed gas .
This equation of state was originally designed to model water for underwater
explosions.
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(9)
(10)
/EOS/STIFF-GAS/mat_ID/unit_ID
eos_title
P0
Psh
Definition
Field
Contents
SI Unit Example
mat_ID
Material identifier.
(Integer, maximum
10 digits)
unit_ID
Unit Identifier.
(Integer, maximum 10 digits)
eos_title
EOS title.
(Character, maximum 100
characters)
Heat capacity ratio .
(Real)
P0
Initial pressure.
(Real)
Psh
Pressure shift.
(Real)
EOS additional pressure
term.
(Real)
Reference density.
Default = material
density (Real)
Example (Water)
/UNIT/1
unit for mat
g mm ms
/MAT/LAW06/7/1
water
# RHO_I
0.001
# NU PMIN
/EOS/STIFF-GAS/7/1
STIFF_GAS_WATER
# GAMMA P0 PSH P_STAR RHO0
6.1 0.10 0 368.85
/ALE/MAT/7
#enddata
(1)
Where,
The stiffened gas EOS introduces an
additional pressure term () with respect to the ideal gas equation of state. The EOS is
stated in this form because the speed of sound in water is:(2)
This way, by considering , the speed of sound will not be affected by fluctuations and .
can be calculated with:(3)
As , leads to a good estimate of .
The stiffened gas EOS 1 can be derived from a polynomial EOS:(4)
Where,
For example, for water, , and can be found in literature. 1 This leads to. Thus, the stiffened gas EOS will give the following
behavior at atmospheric pressure:
Equations of state are used by
Radioss to compute the hydrodynamic pressure and are
compatible with the material laws:
/MAT/LAW3 (HYDPLA)
/MAT/LAW4 (HYD_JCOOK)
/MAT/LAW6 (HYDRO or HYD_VISC)
/MAT/LAW10 (DPRAG1)
/MAT/LAW12 (3D_COMP)
/MAT/LAW49 (STEINB)
/MAT/LAW102 (DPRAG2)
/MAT/LAW103 (HENSEL-SPITTEL)
1 Cole, R. H.; "Underwater
Explosions. Princeton University Press" Princeton, New Jersey (1948)
