/FAIL/WILKINS
Block Format Keyword Describes the Wilkins failure model.
/FAIL/WILKINS/mat_ID/unit_ID | |||||||||
α | Ifail_sh | Ifail_so |
fail_ID |
Definition
mat_ID | Material
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
α | Hydrostatic pressure
exponent. (Real) |
Deviatoric
coefficient. (Real) |
limit. (Real) |
Critical
damage. (Real) |
Ifail_sh | Shell failure flag.
(Integer) |
Ifail_so | Solid failure flag.
(Integer) |
fail_ID | Failure criteria identifier. 2 (Integer, maximum 10 digits) |
Example (Metal)
#RADIOSS STARTER
/UNIT/1
unit for mat
# MUNIT LUNIT TUNIT
Mg mm s
#- 1. MATERIALS:
/MAT/PLAS_JOHNS/1/1
Metal
# RHO_I
2.8E-9 0
# E Nu
60000 .3
# a b n EPS_p_max SIG_max0
370 190 .4 0 0
# c EPS_DOT_0 ICC Fsmooth F_cut Chard
0 0 0 0 0 0
# m T_melt rhoC_p T_r
0 0 0 0
/FAIL/WILKINS/1/1
# Alpha Beta Plim Df Ifail_sh Ifail_so
1.8 .75 750 0.3 1 0
#enddata
- The cumulative
damage is:
Where,
Where,- P
- Hydro pressure
Where, are the deviatoric stresses.
- The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
