/FAIL/XFEM_FLD (Obsolete)
Block Format Keyword Describes a XFEM (eXtended Finite Element Method) failure model.
/FAIL/XFEM_FLD/mat_ID/unit_ID | |||||||||
fct_ID | Ifail_sh |
Optional Line
fail_ID |
Definition
mat_ID | Material
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
fct_ID | Function
identifier (Integer) |
Ifail_sh | Shell failure flag
(Integer) |
fail_ID | (Optional) Failure
criteria identifier 2 (Integer, maximum 10 digits) |
- This failure model is
available for Shell only.
Figure 1. - The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
