/GAUGE
Block Format Keyword Defines gauges.
/GAUGE/gauge_ID/unit_ID
gauge_title
node_ID         shell_ID DIST
Definition
gauge_ID Gauge identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
gauge_title Gauge title.
node_ID Node identifier.
(Integer)
shell_ID Shell identifier.
(Integer)
DIST Distance between gauge and shell surface.
> 0
Gauge in the side pointed by normal of shell surface.
< 0
Gauge in the opposite side of the normal of shell surface.
Default = 0 (Real)
[ m ]
  1. Pressure gauges can be defined by:
    • A node using a node identifier (node_ID > 0), or
    • A shell element (shell_ID) and a distance (DIST). In this case node_ID must be equal to 0.
  2. Pressure gauges have a few restrictions:
    • Only 4-node shells can be used for shell_ID
    • For Coupled Euler Lagrange interface only - shells (shell_ID) must be used with a distance (DIST) greater than interface TYPE18 gap
    • For Finite Volume Method only - nodes (node_ID) must be used
