ALE
- /Keyword1/Keyword2/Keyword3/ . . .
This section of the manual provides information on specific keywords used in an ALE computation:
The sections may be input in any order and may appear several times.
Comment lines should begin with a # or $.
Input data is read in free format with 100 characters per line of data. Every variable must be given and must be separated by at least one blank.
The first character of the free format input file Runname_run#.rad must be a #.
If a non-compulsory section is missing, default values will be used.
