Engine Keyword In this group of keywords are used to generally define the output style, control of computation, damping and ALE setup
during the computation.
Engine Keyword Solid element control for elements with negative volumes. Switch to small strain formulation or stop the run a solid
elements volume becomes negative.
Generates animation files containing results according to the keywords specified. The keywords are specified in the
topics within Animation and Post-processing Output Files.
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling
or quasi-static), different options to control the implicit computation, different implicit time step method and
implicit output messages are introduced.
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF)
and initial condition (rotational/translational velocity).
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, etc.) for different entities (shell, brick, beam, airbag, interface, etc.) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature,
etc.) in state file (STA-File).
/MASS/RESET Engine Keyword Reset the mass of the model to the initial mass computed at t=0.
/MON Engine Keyword Provides an estimation of the CPU time spent for each processor.
/NEGVOL Engine Keyword Solid element control for elements with negative volumes. Switch to small strain formulation or stop the run a solid elements volume becomes negative.
/PARITH Engine Keyword Turns the parallel arithmetic ON/OFF.
/RAD2RAD/ON Engine Keyword To activate Multi-Domain coupling, Radioss Engine Input file must contain the following directive.
/RERUN Engine Keyword Permits to continue a previous Radioss run.
