/H3D/SHELL
Engine Keyword Generate H3D contour output results for /SHELL and /SH3N shell elements.
/H3D/SHELL/Keyword3/Keyword4/Keyword5
#optional next line(s) that lists the parts to save results for.
part_ID1 ... part_IDN
/H3D/SHELL/TENS/STRESS/PLY=1/NPT=ALL
/H3D/SHELL/TENS/STRESS/NPT=ALL/PLY=1
/H3D/SHELL/ENER
356 293
/H3D/SHELL/USER/NPT=ALL/UVAR=12
Definition
- The syntax /H3D/ELEM/Keyword3/Keyword4/Keyword5 is also valid.
- When PART IDs are listed after the /H3D/SHELL line the specified results will output only for those parts.
- Output can be a, scalar, vector,
or tensor as defined in the following tables.
Table 1. Scalar Output Keyword3 Keyword4 Description ALPHA - PLY=
- I or ALL
- LAYER=
- I or ALL
Shear angle alpha of material /MAT/LAW58 in degrees. AMS Elements using AMS timestep due to /DT/CST_AMS. BULK Artificial Viscosity DAM1, DAM2, DAM3 Principal damage values in local orthotropic skew direction 1, 2 or 3 for materials LAW15 and LAW25. DAMA - MEMB
- PLY=
- I or ALL
- LAYER=
- I or ALL
- NPT=
- I, ALL, LOWER or UPPER
Maximum of damage over time of all /FAIL criteria acting on one material. Refer to the specific /FAIL law used for how damage is calculated. TMAX Maximum of damage over time, integration points and failure models. DAMG - MEMB
- NPT=
Mean damage over thickness integration points (only for coupled damage models). 8 DENS Density DOMAIN SPMD domain number of an element. DT Element timestep EINT Element internal energy ENER Specific energy density (internal energy divided by the element mass) TMAX Maximum specific energy density over time EPSD Equivalent strain rate EPSP - PLY=
- I or ALL
- LAYER=
- I or ALL
- NPT=
Plastic strain ERROR THICK Estimated error on shell thickness FAIL - PLY=
- I or ALL
Number of failed layers for /PROP/TYPE10, /PROP/TYPE11, /PROP/TYPE17, /PROP/TYPE51, /PCOMPP, /MAT/LAW15 and /MAT/LAW25. For the other property sets and material laws the values are: no failure =0 and element failed =1. FLDF - MEMB
- LAYER=
- I or ALL
- NPT=
FLD damage factor indicator. 6 FLDZ - MEMB
- LAYER=
- I or ALL
- NPT=
FLD failure zone factor for the FLD failure model. 7 - = 1
- Loose metal
- = 2
- High wrinkle
- = 3
- Compression
- = 4
- Safe
- = 5
- Marginal
- = 6
- Failure
GROUP Internal group identifier HOURGLASS Hourglass Energy MASS Element mass MDS Automatic selection of user variable to output according to MDS law that is used. (1 value per user variable and per ply in case of stack and ply)
MDS - MDS_VAR =
- DEF or ALL (mandatory)
- PLY=
- I or ALL
- LAYER=
- I or ALL
- NPT=
MDS user variables NL_EPSD - NPT=
Non-local plastic strain rate (only if /NONLOCAL/MAT is activated) 10 NL_EPSP - NPT=
Non-local plastic strain (only if /NONLOCAL/MAT is activated) 10 NXTF - MEMB
- LAYER=
- I or ALL
- NPT=
Instability factor of /FAIL/NXT failure model OFF Element status. Where the result output is:- = -1
- Element is not active (it is defined in an activated rigid body).
- = 0
- Deleted element.
- Between 0 and 1
- Under failure process.
- = 1
- Active element.
PEXT External pressure applied on shell element coming from /PLOAD, /LOAD/PFLUID, /LOAD/PBLAST or /LOAD/PRESSURE. PHI - MEMB
- PLY=
- I or ALL
- NPT=
Angle between the element system and direction 1 orthotropy SIGEQ Equivalent stress based on a material’s yield criteria. Some examples of yield criteria are von Mises, Hill or Barlat. TMAX Maximum equivalent stress based on a material’s yield criteria over time and integration points. SIGX, SIGY, SIGZ, SIGXY, SIGYZ, SIGZX Stress in specified direction TDEL Time at which element is deleted, due to failure defined using /FAIL criterion. Failure criteria built in materials is ignored. TEMP Temperature THICK Thickness THIN % thinning for shell. USER - PLY=
- I or ALL
- LAYER=
- I or ALL
- NPT=
- UVAR=
- I or ALL
User material (/MAT/USERij) law output for user-defined variable i. Also, requests USR output for some Radioss material laws such as LAW58. USR1 output is requested using UVAR=1. VONM von Mises stress at neutral fiber TMAX Maximum von Mises stress at neutral fiber over time and integration points WPLA - PLY=
- I or ALL
- LAYER=
- I or ALL
- NPT=
Plastic work for /MAT/LAW15 (CHANG) and /MAT/LAW25 (COMPSH) Table 2. Tensor Output Keyword3 Keyword4 Keyword5 Description TENS BSTRESS - ID=
- n or ALL
- MEMB
- BEND
- PLY=
- I or ALL
- LAYER=
- I or ALL
- NPT=
- I or ALL
Backstress tensor for material /MAT/LAW36 (n=1) and /MAT/LAW78 (n=1, 2 or 3) and /MAT/LAW87 (n=1, 2, 3 or 4). ID=-1 gives the sum of all backstress tensors available for the element.
EPSDOT - MEMB
- BEND
- PLY=
- I or ALL
- LAYER=
- I or ALL
- NPT=
- I or ALL
Strain rate tensor STRAIN - MEMB
- BEND
- PLY=
- I or ALL
- LAYER=
- I or ALL
- NPT=
Strain tensor TMAX Strain tensor corresponding to the maximum principal strain (P1) over time and integration points. Strain tensor corresponding to the minimum principal strain (P3) over time and integration points.
STRAIN_ENG -- Infinitesimal total strain. Only one tensor per element. STRESS - MEMB
- BEND
- PLY=
- I or ALL
- LAYER=
- I or ALL
- NPT=
- I or ALL
Stress tensor TMAX Stress tensor corresponding to the maximum principal stress (P1) over time and integration points. Stress tensor corresponding to the minimum principal stress (P3) over time and integration points.
- The output location in
Keyword4 and Keyword5 can be defined
via:
- NPT
- Integration points.
- LAYER
- Composite shell layer when using /PROP/TYPE11 (SH_SANDW), /PROP/TYPE10 (SH_COMP).
- PLY
- Composite shell ply when using, /PROP/TYPE19 (PLY) or /PLY.
- MEMB
- Generalized membrane stresses per element. Cannot be used with NPT, LAYER or PLY options.
- BEND
- Generalized bending stresses per element. Cannot be used with NPT, LAYER or PLY options.
- Output can be requested for a specific location number (I), ALL, and in some case UPPER or LOWER. The output locations are separated by a / and can be in any order.
- The values of FLD damage factor
is equal to the ratio of the actual major principal strain value over the
forming limit curve value:
(1) Where, is the major principal strain at failure limit from FLD diagram (fct_ID in /FAIL/FLD).
The FLD compares the and using the same .
Figure 1.FLDF may be greater than 1, if the option /FAIL/FLD, Ifail_sh=4 is used. In this case, the damage factor is only calculated for post-processing and no elements are deleted.
- The values of FLD zone index are
defined as:
- FLDZ=6
- Failure
- FLDZ=5
- Marginal
- FLDZ=4
- Safe
- FLDZ=3
- Compression
- FLDZ=2
- High wrinkle
- FLDZ=1
- Loose metal
Figure 2.Where,- fct_ID
- Defined in /FAIL/FLD
- Major strain as a limit from FLD diagram from fct_ID in /FAIL/FLD
- and
- The minimum and maximum principal strains
- Rani
- Average anisotropy factor defined in FLD input in /FAIL/FLD
- Defined in FLD input in /FAIL/FLD
(2) - I_marg
- Option DAMG is
only used with coupled damage models (/MAT/LAW72 or
/FAIL/GURSON) to output damage over integration points.
The damage variable is normalized by its critical value.
- For /MAT/LAW72
(5) - For /FAIL/GURSON
(6)
- For /MAT/LAW72
- When using global integration (N=0 in the shell property), Radioss always outputs the stress and strain only in the midplane (MEMB).
- If /NONLOCAL/MAT option is activated, it is possible to output the regularized non-local plastic strain and its rate.
