/INIBEAM/FULL
Block Format Keyword Describes the initial state for beam elements. All values defined in the following card will be applied at the beginning on the computation.
/INIBEAM/FULL/unit_ID | |||||||||
beam_ID | nb_integr | prop_type | |||||||
EImemb | EIbend | ||||||||
F1 | F2 | F3 | |||||||
M1 | M2 | M3 |
Definition
unit_ID | Optional unit
beam_ID | Element
identifier (Integer) |
nb_integr | Integration point
number through the section 1 It corresponds to the property definition of this element. (Integer) |
prop_type | Beam property set.
2 (Integer) |
EImemb | Total membrane
energy (Real) |
EIbend | Total bending
energy (Real) |
F1 | Beam element normal
force along X direction (Real) |
F2 | First beam element
share force (XY) (Real) |
F3 | Second beam element
share force (XZ) (Real) |
M1 | Beam element moment
around X direction (Real) |
M2 | Beam element moment
around Y direction (Real) |
M3 | Beam element moment
around Z direction (Real) |
Beam normal
stress (Real) |
First shear
stress (Real) |
Second shear
stress (Real) |
Plastic
strain (Real) |
- The nb_integr must be equal to the number of integration points given in the beam property.
- If nb_integr > 0 (integrated beam – TYPE18), repeat the optional continuation lines for each integration point.
