/INIBRI/STRA_F
Block Format Keyword Describes the initial state for a brick.
/INIBRI/STRA_F/unit_ID
brick_ID Nb_integr Isolnod Isolid nptr npts nptt nlay
For each integration point (Nb_integr > 0)
ε 1 ε 2 ε 3
ε 12 ε 23 ε 31
Definition
unit_ID Unit Identifier.
(Integer, maximum 10 digits)
brick_ID Element identifier.
(Integer)
Nb_integr Number of integration points.
Corresponds to the property definition of this element.
(Integer)
Isolnod Number of nodes of solid element.
(Integer)
Isolid Solid element formulation.
Corresponds to the solid element formulation in property definition of this element.
(Integer)
nptr Number of integration points in direction r.
(Integer)
npts Number of integration points in direction s.
(Integer)
nptt Number of integration points in direction t.
(Integer)
nlay Number of layers for thick shell elements.
(Integer)
ε 1 Strain in direction 1.
(Real)
ε 2 Strain in direction 2.
(Real
ε 3 Strain in direction 3.
(Real
ε 12 Strain in direction 12.
(Real
ε 23 Strain in direction 23.
(Real
ε 31 Strain in direction 31.
(Real
  1. The initial state for brick may be defined by more than one block.
