/INIBRI/STRA_FGLO
Block Format Keyword Describes the initial strain state for a brick in global reference system.
/INIBRI/STRA_FGLO/unit_ID | |||||||||
brick_ID | Nb_integr | Isolnod | Isolid | nptr | npts | nptt | nlay |
1 | 2 | 3 | |||||||
12 | 23 | 31 |
Definition
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
brick_ID | Element identifier.
(Integer) |
Nb_integr | Number of integration
points. Corresponds to the property definition of this element. (Integer) |
Isolnod | Number of nodes of solid
Isolid | Solid element
formulation. Corresponds to the solid element formulation in property definition of this element. (Integer) |
nptr | Number of integration
points in direction r. (Integer) |
npts | Number of integration
points in direction s. (Integer) |
nptt | Number of integration
points in direction t. (Integer) |
nlay | Number of layers for thick
shell elements. (Integer) |
1 | Strain in direction
1. (Real) |
2 | Strain in direction
2. (Real |
3 | Strain in direction
3. (Real |
12 | Strain in direction
12. (Real |
23 | Strain in direction
23. (Real |
31 | Strain in direction
31. (Real |
- The initial state for brick may be defined by more than one block.
