/INIMAP2D
Block Format Keyword Map 2D velocity and thermodynamic values into a 3D axi-symmetric space for use with /ALE/EULER materials.
/INIMAP2D/form/inimap2d_ID | |||||||||
inimap2d_title | |||||||||
node_ID1 | node_ID2 | node_ID3 | |||||||
grbric_ID | grquad_ID | grtria_ID | |||||||
f2d_IDv | Fscalev | ||||||||
f2d_IDvf1 | f2d_IDrho1 | Fscalerho1 | f2d_IDp_e1 | Fscalep_e1 | |||||
etc | etc | etc | etc | etc | |||||
f2d_IDvfN | f2d_IDrhoN | FscalerhoN | f2d_IDp_eN | Fscalep_eN |
Definition
form | Initial state formulation.
inimap2d_ID | Inimap2d block identifier. (Integer, maximum 10 digits) |
inimap2d_title | Inimap2d block title. (Character, maximum 100 characters) |
node_ID1 | Node 1 identifier. (Integer, maximum 10 digits) |
node_ID2 | Node 2 identifier. (Integer, maximum 10 digits) |
node_ID3 | Node 3 identifier. (Integer, maximum 10 digits) |
grbric_ID | Brick group on which initialization is
performed. (Integer) |
grquad_ID | Quad group on which initialization is
grtria_ID | Tria group on which initialization is performed. (Integer) |
f2d_IDv | Function identifier
(/FUNC_2D) for velocity initialization. (Integer) |
Fscalev | Velocity scale factor. 4 (Integer) |
Repeat the following lines for each /MAT/LAW151 or /MAT/LAW51 submaterial 1 through N | ||
f2d_IDvf1 | 2D function identifier
(/FUNC_2D) for volume fraction
(Integer) |
f2d_IDrhoi | 2D function identifier
(/FUNC_2D) for density
(Integer) |
Fscalerhoi | Density scale factor. 4
(Real) |
f2d_IDp_ei | If
form=VE, 2D function identifier
(/FUNC_2D) for energy
. If form=VP, 2D
function identifier (/FUNC_2D) for pressure
(Integer) |
Fscalep_e1 | If
form=VE, Energy scale factor. 4 If form=VP, Pressure scale factor. (Real) |
or |
/INIMAP2D/VE/1
INIMAP2D1
# node_ID1 node_ID2 node_ID3
130602 131262 96789
#grbric_ID grquad_ID grsh3n_ID
1 0 0
# fct_u
3
# fct_alp fct_rho fct_eint
0 1 0
/FUNC_2D/1
for density initialization
# dim
1
# X Y Z1
# X-coord Y-Coord density
0.00000000 0.00000000 109.00000000
0.00195695 0.00000000 114.00000000
0.00391389 0.00000000 111.00000000
0.00587084 0.00000000 109.00000000
0.00782779 0.00000000 114.00000000
/FUNC_2D/3
# dim
2
# X Y Z1 Z2
# X-coord Y-Coord velocity x velocity y
0.00097656 0.00097656 -0.00026680 -0.02174114
0.00097656 0.00292969 -0.00080037 -0.02173459
0.00097656 0.00488281 -0.00133382 -0.02172149
0.00097656 0.00683594 -0.00186707 -0.02170185
0.00097656 0.00878906 -0.00240003 -0.02167567
#enddata
- node_ID1, node_ID2 and node_ID3 define the local coordinate system used for mapping.
Where, node_ID1 and node_ID2 define
node_ID1 and node_ID3 define
- The coordinates of 2D data that will be mapped are defined in the local and system using the /FUNC_2D X and Y input.
- When mapping scalar quantities such as density, pressure and energy, use /FUNC_2D with dim=1 and define the scalar value using Z1. For vector quantities such as velocity, use /FUNC_2D with dim=2 and define the vector using Z1 and Z2 (Figure 2 and Figure 3).
- If any inputs for veloctiy, volume fraction, density, energy, or pressure are constant, then the function can be left undefined and the constant values can be entered in the scale factor fields, Fscalev, Fscalerhoi, or Fscalep_e1. If functions are defined, then the default value for the scale factors are 1.0.
- When form=VE, the model is initialized from density, specific internal energy and velocity. This formulation is available for all mono-material ALE / EULER material laws and with material /MAT/LAW151 (MULTIFLUID) and /MAT/LAW51 (MULTIMAT).
- When form=VP, the model is initialized from density, pressure and velocity. This formulation is available for all mono-material ALE / EULER material laws whose equation of state is provided through the /EOS card and with material /MAT/LAW151 and /MAT/LAW51 only if Iform= 12 is used.
- If explosive material LAW5 (JWL) is used as submaterial, then mapping will be proceeded considering all explosive was burnt (burn fraction = 1.0). The mapping will be done with detonation products only with a burn fraction = 1.0.
