/INISHE/AUX or /INISH3/AUX
Block Format Keyword This option is used to initialize internal variables of user type material laws for shells (UVAR buffer).
/INISHE/AUX or /INISH3/AUX | |||||||||
shell_ID | nb_integr | npg | nvars |
V1 | V2 | V3 | Vnvars |
Definition
shell_ID | Element
identifier (Integer) |
nb_integr | Integration point number
through the thickness It corresponds to the property definition of this element. Must be equal to the number of integration points given in the shell property. (Integer) |
npg | Number of surface
quadrature points. Must be set according to the formulation which is
used in the shell property.
(Integer) |
nvars | Number of auxiliary
internal variables. Is the number of the first user variables to be
initialized for a shell. It must be less or equal to the total
number of internal variables used in a user type law
(NUVAR). (Integer) |
V1 | 1st auxiliary
variable value (Real) |
Vnvars | nvarsth auxiliary variable
value (Real) |
- It also may be necessary to complete the initial state of shells issued from a previous Radioss run. In this case, these values may be obtained during the previous Radioss Engine run, using option /STATE/SHELL/AUX/FULL.
- It must be noticed that the contents of the blocks will not necessarily be detailed.
- For npg = 0 or 1 and nb_integr > 0, the sequence Line 4 has to be repeated for each integration point.
- For npg =
3 or 4, sequence Line 4 must be repeated for each quadrature point and for each
integration point as follows:
- repeat for each quadrature point
- repeat for each integration point
- Line 4
- The initial state for shells may be defined by more than one block.
