/INISHE/EPSP or /INISH3/EPSP
Block Format Keyword Describes the initial plastic strain for a shell.
/INISHE/EPSP/unit_ID or | |||||||||
/INISH3/EPSP/unit_ID | |||||||||
shell_ID | p |
Definition
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
shell_ID | Element
identifier (Integer) |
p | Plastic
strain (Real) |
- If the shell property uses several integration points, the given plastic strain value is set to each integration point.
