/INISHE/STRA_F/GLOB or /INISH3/STRA_F/GLOB
Block Format Keyword Describes the initialization strain for shell elements in the global coordinate system.
/INISHE/STRA_F/GLOB/unit_ID or /INISH3/STRA_F/GLOB/unit_ID | |||||||||
shell_ID | nb_integr | npg | Thick |
T |
Definition
unit_ID | Optional unit
identifier. (Integer, maximum 10 digits) |
shell_ID | Element
identifier. (Integer) |
nb_integr | Integration point number through
the thickness. Default = 2 (Integer) |
npg | Number of surface quadrature points.
(Integer) |
Thick | Shell
thickness. (Real) |
Plane strain XX in the global
frame. (Real) |
Plane strain YY in the global
frame. (Real) |
Plane strain ZZ in the global
frame. (Real) |
Shear strain XY in the global
frame. (Real) |
Shear strain YZ in the global
frame. (Real) |
Shear strain ZX in the global
frame. (Real) |
T | Parametric position of the
integration points throughout the Thickness (between -1 and
1). (Real) |
- The nb_integr should be equal to the nb_integr defined in the shell property definition.
- The npg must be set according to the formulation which is used in the shell property.
- If nb_integr ≠ 0, repeat the optional continuation lines for each integration point.
- The initial state for shells may be defined by more than one block.
