/INISHE/THICK or /INISH3/THICK
Block Format Keyword Describes the initialization of thickness for shells element per element.
/INISHE/THICK/unit_ID or /INISH3/THICK/unit_ID
shell_ID     Thick
Definition
unit_ID Unit Identifier.
(Integer, maximum 10 digits)
shell_ID Element identifier.
(Integer)
Thick Shell thickness.
(Real)
[ m ]
  1. This option can be used to initialize the Thickness for shells element per element. By default, property defined characteristics are used, those defined using this option are priority.
  2. This option cannot be used to initialize shells with TYPE11 and TYPE16 properties.
