/INISPRI/FULL
Block Format Keyword Describes the initial state for spring elements. All values defined in this card will be applied at the beginning on the computation.
/INISPRI/FULL/unit_ID
spring_ID prop_type nvars
If prop_type = 4:
FX DX FEPX DPLX+ DPLX-
LX EI
If prop_type = 12:
LX EI DFS
If prop_type = 26:
FX DX FEPX
LX EI DV
If prop_type = 8, 13, 25:
FY DY FEPY DPLY+ DPLY-
FZ DZ FEPZ DPLZ+ DPLZ-
MX RX MEPX RPLX+ RPLX-
MY RY MEPY RPLY+ RPLY-
MZ RZ MEPZ RPLZ+ RPLZ-
LX LY LZ EI EDX
EDY EDZ ERX ERY ERZ
If prop_type = 29, 30, 31, 32, 33, 35, 36, 44, 45, 46:
FX DX
FY DY
FZ DZ
MX RX
MY RY
MZ RZ
EI
V1 V2 VR3   Vnvars
Definition
unit_ID Optional unit identifier.
(Integer, maximum 10 digits)
spring_ID Element identifier.
prop_type Property set. 2
nvars Number of user element variables .
FX Spring element force along X direction.
(Real)
[ N ]
FY Spring element force along Y direction.
(Real)
[ N ]
FZ Spring element force along Z direction.
(Real)
[ N ]
MX Spring element moment around X direction.
(Real)
[ Nm ]
MY Spring element moment around Y direction.
(Real)
[ Nm ]
MZ Spring element moment around Z direction.
(Real)
[ Nm ]
DX Spring element elongation along X direction.
(Real)
[ m ]
DY Spring element elongation along Y direction.
(Real)
[ m ]
DZ Spring element elongation along Z direction.
(Real)
[ m ]
RX Spring element rotation around X direction.
(Real)
[ rad ]
RY Spring element rotation around Y direction.
(Real)
[ rad ]
RZ Spring element rotation around Z direction.
(Real)
[ rad ]
FEPX Spring elastic-plastic force along X direction.
(Real)
[ N ]
FEPY Spring elastic-plastic force along Y direction.
(Real)
[ N ]
FEPZ Spring elastic-plastic force along Z direction.
(Real)
[ N ]
MEPX Spring elastic-plastic moment around X direction.
(Real)
[ Nm ]
MEPY Spring elastic-plastic moment around Y direction.
(Real)
[ Nm ]
MEPZ Spring elastic-plastic moment around Z direction.
(Real)
[ Nm ]
DPLX+ Max displacement in positive X direction.
(Real)
[ m ]
DPLY+ Max displacement in positive Y direction.
(Real)
[ m ]
DPLZ+ Max displacement in positive Z direction.
(Real)
[ m ]
RPLX+ Max rotation in positive X direction.
(Real)
[ m ]
RPLY+ Max rotation in positive Y direction.
(Real)
[ m ]
RPLZ+ Max rotation in positive Z direction.
(Real)
[ m ]
DPLX+ Max displacement in negative X direction.
(Real)
[ m ]
DPLY+ Max displacement in negative Y direction.
(Real)
[ m ]
DPLZ+ Max displacement in negative Z direction.
(Real)
[ m ]
RPLX+ Max rotation in negative X direction.
(Real)
[ rad ]
RPLY+ Max rotation in negative Y direction.
(Real)
[ rad ]
RPLZ+ Max rotation in negative Z direction.
(Real)
[ rad ]
LX Spring length along X direction.
(Real)
[ m ]
LY Spring length along Y direction.
(Real)
[ m ]
LZ Spring length along Z direction.
(Real)
[ m ]
EDX Deformation energy positive X direction.
(Real)
[ J ]
EDY Deformation energy positive Y direction.
(Real)
[ J ]
EDZ Deformation energy positive Z direction.
(Real)
[ J ]
ERX Rotation energy around X direction.
(Real)
[ J ]
ERY Rotation energy around Y direction.
(Real)
[ J ]
ERZ Rotation energy around Z direction.
(Real)
[ J ]
DFS Relative force between pulley branches. 2
(Real)
[ N ]
DV Spring velocity filtering. 3
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
EI Total internal energy.
(Real)
[ J ]
VR1 1st user variable value.
(Real)
VR2 2nd user variable value.
(Real)
VR3 3rd user variable value.
(Real)
Vnvars nvarsth user variable value. 4
(Real)
  1. The initial state for spring may be defined by more than one block (for the same spring type only).
  2. The relative force between pulley branches, DFS, is available only for spring property /PROP/TYPE12 (SPR_PUL).
  3. Spring velocity filtering, DV, is available only for spring property TYPE26. It is based on strain rate filtering factor (ALPHA – see /PROP/TYPE26 (SPR_TAB)).
  4. The nvars is the number of the first user variables to be initialized for a spring. It must be less or equal to the total number of internal variables used in a user type law (NUVAR).
