/INIV/TRA/Keyword3/2
Engine Keyword Initialize translational velocity in the specified direction X, Y or Z on a node set.
V
grnd_ID
Definition
Keyword3 X, Y or Z.
V Translational velocity. [ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
grnd_ID Node group (/GRNOD) or node set (/SET) on which specific initial velocities are applied.
  1. The nodes defined in the node set grnd_ID have the translational velocity V.
