/INIVEL/FVM
Block Format Keyword Defines initial material velocities on a group of elements (bricks, quad or triangles) for the Finite Volume solver.
/INIVEL/FVM/inivel_ID/unit_ID | |||||||||
inivel_title | |||||||||
VX. | VY. | VZ | grbric_ID | grqd_ID | grtria_ID | skew_ID |
Definition
inivel_ID | Initial velocity block
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
inivel_title | Initial velocity block
title. (Character, maximum 100 characters) |
VX | X
velocity (Real) |
VY | Y
velocity. (Real) |
VZ | Z
velocity. (Real) |
grbric_ID | Brick group on which
specific initial velocities are applied. (Integer) |
grqd_ID | Quad groups on which
gria_ID | Tria groups on which
skew_ID | Skew
identifier. (Integer) |
- At least one group ID must be provided.
- /INIVEL/FVM is used to initialize velocities in solid elements for the Finite Volume solver of /MAT/LAW151 (MULTIFLUID).
