/INIVEL
Block Format Keyword Defines initial velocity on a group of nodes.
/INIVEL/type/inivel_ID/unit_ID | |||||||||
inivel_title | |||||||||
VX | VY | VZ | grnd_ID | skew_ID |
Definition
type | Initial velocity type.
inivel_ID | Initial velocity block
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
inivel_title | Initial velocity block
title. (Character, maximum 100 characters) |
VX | X
velocity. (Real) |
or |
VY | Y
velocity. (Real) |
or |
VZ | Z
velocity. (Real) |
or |
grnd_ID | Node group on which
specific initial velocities are applied. (Integer) |
skew_ID | Skew
identifier. (Integer) |
- The grnd_ID input is obligatory. The initial velocities will only be applied to nodes belonging to a node group.
- Unit of velocity in translation is . In rotation, then angle is in unit and thus the velocity is in unit .
