/INTER/TYPE14
Block Format Keyword This interface simulates impacts between a hyper-ellipsoidal rigid main surface and a list of secondary nodes. The hyper-ellipsoidal surface is treated as an analytical surface (hyper-ellipsoidal surfaces are only discretized for post-processing).
For this interface, generally, use a mesh whose size is finer than the lowest semi- axis of main surface. The main surface must be a MADYMO hyper-ellipsoidal surface or a Radioss hyper-ellipsoidal surface.
/INTER/TYPE14/inter_ID/unit_ID
inter_title
grnd_IDs surf_IDm fct_IDld fct_IDf fct_IDd1 fct_IDd2
Stif Fric Visc Gap
Definition
inter_ID Interface identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
inter_title Interface title.
grnd_IDs Secondary nodes group identifier.
(Integer)
surf_IDm Main surface identifier.
(Integer)
fct_IDld Elastic force versus penetration function identifier.
(Integer)
fct_IDf Friction coefficient versus elastic force function identifier.
Default = 1 (Integer)
fct_IDd1 Damping coefficient versus normal velocity function identifier.
fct_IDd2 Damping coefficient versus elastic force function identifier.
Stif Interface stiffness.
No default (Real)
[ N m ]
Fric Friction coefficient.
No default (Real)
Visc Normal viscosity coefficient.
No default (Real)
[ kg s ]
Gap Gap for impact activation.
No default (Real)
[ m ]
  1. Elastic force is defined as:(1)
    F e total = F e local = Stif f l d ( Penetratio n max )
    While,
    F e total = Stif Penetration , if fct_IDld is 0
    F e total = Stif f l d ( Penetratio n max ) Penetration P e n e t r a t i o n s , otherwise f l d is function of fct_IDld
  2. Tangential force is defined as:(2)
    F t Fric f f ( F e local ) F e local
    With f f is function of fct_IDf
  3. Damping force is defined as:(3)
    F d = C V n
    With, V being the normal velocity of the secondary node:(4)
    C = V i s c f d 1 ( V n ) f d 2 ( F e l o c a l ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGdbGaey ypa0JaamOvaiaadMgacaWGZbGaam4yaiabgwSixlGacAgadaWgaaWc baGaamizaiaaigdaaeqaaOWaaeWaaeaacaWGwbWaaSbaaSqaaiaad6 gaaeqaaaGccaGLOaGaayzkaaGaeyyXICTaciOzamaaBaaaleaacaWG KbGaaGOmaaqabaGcdaqadaqaaiaadAeadaWgaaWcbaGaamyzaaqaba GcdaahaaWcbeqaaiaadYgacaWGVbGaam4yaiaadggacaWGSbaaaaGc caGLOaGaayzkaaaaaa@51D2@
    f d 1 and f d 2 are functions of fct_IDd1 and fct_IDd2.
