/INTER/TYPE9
Block Format Keyword Describes the ALE Lagrange with void opening and free space. Non-impacted ALE nodes are on a free surface. The grid velocity is equal to the material velocity in normal direction. The normal of the main surface elements must be oriented toward the secondary nodes.
/INTER/TYPE9/inter_ID | |||||||||
inter_title | |||||||||
surf_IDA | surf_IDL | ||||||||
RTH | Fric | Gap | |||||||
ITH | IEUL | Upwind | FS |
Definition
inter_ID | Interface
identifier. (Integer, maximum 10 digits) |
inter_title | Interface
title. (Character, maximum 100 characters) |
surf_IDA | ALE secondary surface
identifier. (Integer) |
surf_IDL | Lagrangian main surface identifier.
(Integer) |
RTH | Thermal resistance per
surface unit. (Real) |
Fric | Coulomb
friction. (Real) |
Gap | Gap for impact
activation. (Real) |
ITH | Thermal bridge flag.
(Integer) |
IEUL | Eulerian behavior in
tangent direction flag.
(Integer) |
Upwind | Upwind for free surface
normal computation.
(Real) |
FS | Surface tension
force. (Real) |
- Format Line 5 is not compatible with the main/secondary formulation of rigid bodies. If some nodes of the Lagrangian main surface are in a rigid body, the rigid body motion does not take into account the interfaces forces applied to these nodes.
