/LEAK/MAT
Block Format Keyword Specifies effective leakage area of porous airbag fabric materials LAW19 and LAW58 as function of time, pressure, area and other parameters.
/LEAK/MAT/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
Ileakage | AscaleT | AscaleP |
AC' | fct_IDAC' | FscaleAC' |
LC | AC |
fct_IDLC | fct_IDAC | FscaleLC | FscaleAC |
L | R | ||||||||
C1 | C2 | C3 |
X0 | X1 | X2 | X3 |
Definition
mat_ID | Material
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material
Ileakage | Effective leakage area
formulation flag.
(Integer) |
AscaleT | Abscissa time scale factor
on function Default = 1 (Real) |
AscaleP | Abscissa pressure scale
factor on function Default = 1 (Real) |
AC' | Area coefficient for area
in contact
Default = 0 (Real) |
fct_IDAC' | Area coefficient function
identifier AC'(t) if AC' is equal to 0 (Integer) |
FscaleAC' | Scale factor on function
AC' Default = 1 (Real) |
LC | Leakage
coefficient Default function is 0 (Real) |
AC | Area coefficient Default = 0 (Real) |
fct_IDLC | Leakage coefficient
function identifier LC(t), if Ileakage
=2 or 3 Leakage coefficient function identifier , if Ileakage =4 Default function is 0 (Integer) |
FscaleLC | Scale factor on function
LC Default = 1 (Real) |
fct_IDAC | Area coefficient function
identifier
, if Ileakage
=2. Area coefficient function identifier , if Ileakage =3. Area coefficient function identifier , if Ileakage =4. Default function is 0 (Integer) |
FscaleAC | Scale factor on function
AC Default = 1 (Real) |
L | Characteristic
length Default = 1 (Real) |
R | Fiber thickness Default = L (Real) |
C1 | Coefficient
C1 (Real) |
C2 | Coefficient C2 Default = 1 (Real) |
C3 | Coefficient
C3 (Real) |
X0, X1, X2, X3 | Coefficients of
Anagonye-Wang leakage area law (Real) |
- The mat_ID must be the same as /MAT/LAW19 (FABRI) or /MAT/LAW58 (FABR_A). Material porosity is active only when corresponding components are referred as external surfaces in /MONVOL/AIRBAG1, /MONVOL/COMMU1, and /MONVOL/FVMBAG1 airbag cards.
- Effective leakage area (
) formulation:Ileakage =1:
(1) Ileakage =2:(2) Ileakage =3:(3) Ileakage =4:(4) Where,- Initial area of the airbag surface
Note: By default all coefficients and functions are zero.Ileakage =5:(5) Where, and are the stretches in warp and weft directions and is the angle between warp and weft directions.Note: For LAW19Ileakage =6:(6) with and
- Blockage of airbag fabric, due to
contact, can be activated in corresponding /MONVOL card.
Effective leakage area is calculated with account of the blockage as:
(7)
