*LOAD_SHELL
LS-DYNA Input Interface KeywordDefines pressure load on a single shell element or on a set of shell elements.
(1) (2) (3) (4) (5) (6) (7) (8)
*LOAD_SHELL_{OPTION1}_{OPTION2}
If OPTION2 = ID
ID Title
If OPTION1 = ELEMENT (or <blank>)
EID fct_ID Fscaley Tstart
If OPTION1 = SET
ESID fct_ID Fscaley Tstart
Definition
OPTION1
Pressure applied to a given shell element.
SET
Pressure applied to a given set of shell elements.
OPTION2
ID
Defined identifier and title.
Title Load title.
(Character)
EID Element ID.
(Integer)
ESID Element set ID.
(Integer)
fct_ID Pressure versus time load curve identifier.
(Integer)
Fscaley Ordinate (pressure) scale factor.
Default = 1.0 (Real)
[ Pa ]
Tstart Time for pressure activation. Function fct_ID is shifted by Tstart.
Default = 0.0 (Real)
[ s ]
  1. This keyword maps to /PLOAD.
