*MAT_100 (SPOTWELD)
LS-DYNA Input Interface KeywordDefines an elasto-plastic spotweld material for beam element (elform=9) or solid element.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_100 or *MAT_SPOTWELD | |||||||
mat_ID | E | ν | SIGY | ET | |||
EFAIL | NRR | NRS | NRT | MRR | MSS | MTT |
Definition
mat_ID | Material identifier. (Integer) |
Initial density. (Real) |
E | Young’s modulus. (Real) |
v | Poisson’s ratio. (Real) |
SIGY | Yield stress. (Real) |
ET | Plastic hardening modulus. (Real) |
EFAIL | Plastic strain to failure. (Real) |
NRR | Axial failure force (for beam only, only ≥ 0).
EFAIL is ignored. (Real) |
NRS | Shear failure force in local direction S (for beam only, only
≥ 0). EFAIL is ignored. (Real) |
NRT | Shear failure force in local direction T (for beam only, only
MRR | Torsional failure moment (for beam only, only ≥
0). (Real) |
MSS | Bending failure moment along local direction S (for beam
only, only ≥ 0). (Real) |
MTT | Bending failure moment along local direction T (for beam
- This keyword maps to /PROP/TYPE43 (CONNECT), /MAT/LAW59 (CONNECT) and /FAIL/CONNECT.
- This keyword linked to beam elements maps to /PROP/TYPE13 (SPR_BEAM).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
