/MAT/GAS
Block Format Keyword Describes the gas molecular weight and specific heat coefficients.
/MAT/GAS/MASS/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
MW | |||||||||
Cpa | Cpb | Cpc | Cpd | Cpe | |||||
Cpf |
/MAT/GAS/MOLE/mat_ID/unit_ID | |||||||||
MW | |||||||||
/MAT/GAS/PREDEF/mat_ID/unit_ID | |||||||||
4 |
/MAT/GAS/CSTA/mat_ID/unit_ID | |||||||||
CP | CV |
Definition
mat_ID | Material identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material title (Character, maximum 100 characters) |
MW | Molecular weight of gas (Real > 0) |
Cpa | Cpa coefficient in the
relation Cp(T) (Real) |
Cpb | Cpb coefficient in the
Cpc | Cpc coefficient in the
Cpd | Cpd coefficient in the
Cpe | Cpe coefficient in the
Cpf | Cpf coefficient in the
CP | Specific heat at constant
pressure (Real) |
CV | Specific heat at constant
volume (Real) |
Input Type Keyword
- Keyword
- Input Type
- MASS
- Coefficients of Cp(T) per mass unit
- MOLE
- Coefficients of Cp(T) per mole
- PREDEF
- Predefined gas name
- CSTA
- Cp constant with temperature
Example (Gas)
#RADIOSS STARTER
/UNIT/1
unit for mat
kg mm ms
/MAT/GAS/CSTA/5/1
Nitrogen
# cp cv
931.5 634.7
#ENDDATA
/END
- If Type is
MASS:
(1) Where, is the energy per mass unit per Kelvin and is the energy per mass unit per Kelvin.
- If Type is
MOLE:
(2) Where, is the molecular weight, mass per mole; is the energy per mole per Kelvin, and is the energy per mole per Kelvin.
- If Type is CSTA, CP and CV are given per unit mass.
- The units in the database are automatically
translated to the global unit system.Listed below are names of 14 commonly used gases predefined in Radioss: N2, O2, Air, etc. These will be referred to by a gas material identifier, while defining INJECTOR.
- Predefined Gas Name
- Gas
- N2
- Nitrogen
- O2
- Oxygen
- CO2
- Carbon dioxide
- CO
- Carbon monoxide
- AR
- Argon
- NE
- Neo
- HE
- Helium
- H2
- Hydrogen
- H2O
- Water vapor
- NH3
- Ammonia
- N2S
- Hydrogen sulfide
- C6H6
- Benzene
- N2O
- Nitrous oxide
- AIR
- Air
- Gas data is available on the NIST (National Institute of Standard and Technology) web site: http://webbook.nist.gov/chemistry/
