/MAT/LAW104 (JOHNS_VOCE_DRUCKER)
Block Format Keyword An elasto-plastic constitutive law using the 6th order Drücker model with a mixed Voce and linear hardening. Johnson-Cook strain rate dependency and thermal softening effects due to self-heating can also be modeled. The law is available for isotropic shell and solid elements.
/MAT/LAW104/mat_ID/unit_ID or /MAT/JOHNS_VOCE_DRUCKER/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
E | Ires | ||||||||
H | Q | B | CDR | ||||||
CJC | |||||||||
Tref | Tini | ||||||||
Cp |
Definition
mat_ID | Material identifier. (Integer, maximum 10 digits) |
unit_ID | Optional unit
mat_title | Material title. (Character, maximum 100 characters) |
Initial
density. (Real) |
E | Young‘s
modulus. (Real) |
Poisson’s
ratio. (Real) |
Ires | Resolution method for plasticity.
(Integer) |
Initial yield
stress. (Real) |
H | Linear hardening
module. (Real) |
Q | Voce hardening
coefficient. (Real) |
B | Voce hardening
exponent. (Real) |
CDR | Drücker
CJC | Johnson-Cook strain rate
Inviscid limit for the plastic
strain rate. (Real) |
Temperature softening
slope. (Real) |
Tref | Reference temperature at which the
hardening law was identified in experiment. (Real) |
Tini | Initial temperature of material in
simulation. (Real) |
Taylor-Quinney
Cp | Specific heat. (Real) |
Plastic strain rate at isothermic
conditions. (Real) |
Plastic strain rate at adiabatic
- The law uses 6th
order Drücker equivalent stress definition:
(1) Where , are respectively the second and third invariant of the deviatoric stress tensor .
The parameter is user-defined and allows to define several yield surfaces (Figure 1). To respect the convexity, its value must respect -27/8 ≤ CDR ≤ 2.25. - The yield function is
defined as:
(2) and(3) Where,- Initial yield stress.
- H
- Linear hardening.
- Voce hardening parameters.
- Johnson-Cook strain rate coefficient.
- Filtered plastic strain-rate.
- Inviscid limit plastic strain rate.
- Thermal softening slope.
The evolution of this flow stress equation with plasticity. - If
/HEAT/MAT is not used for this material, the
temperature is calculated internally using the incremental
formula:
(4) Where,- Plastic strain energy increment.
- Taylor-Quinney coefficient that must respect .
- Coefficient that defines the transition between isothermal and adiabatic conditions (Figure 3).
(5)
