/MAT/LAW40 (KELVINMAX)
Block Format Keyword This law describes the generalized Maxwell-Kelvin material. This law can only be used with solid elements.
/MAT/LAW40/mat_ID/unit_ID or /MAT/KELVINMAX/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
K | Astass | Bstass | Kvm | ||||||
G1 | G2 | G3 | G4 | G5 | |||||
Definition
mat_ID | Material identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material title (Character, maximum 100 characters) |
Initial density (Real) |
K | Bulk modulus (Real) |
Long time shear
modulus (Real) |
Astass | Stassi A
coefficient (Real) |
Bstass | Stassi B
Kvm | von Mises
G1 | Shear modulus 1 (Real) |
G2 | Shear modulus 2 (Real) |
G3 | Shear modulus 3 (Real) |
G4 | Shear modulus 4 (Real) |
G5 | Shear modulus 5 (Real) |
Time decay constant
1 (Real) |
Time decay constant
2 (Real) |
Time decay constant
3 (Real) |
Time decay constant
4 (Real) |
Time decay constant
5 (Real) |
Example (Elastic Rubber)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/KELVINMAX/1/1
LAW40 elastic rubber
# RHO_I
1E-9
# K G_inf Astass Bstass Kvm
8.97 3 0 0 0
# G1 G2 G3 G4 G5
0 0 0 0 0
# BETA1 BETA2 BETA3 BETA4 BETA5
0 0 0 0 0
#ENDDATA
/END
- Shear
modulus is computed using the following equation:
(1) with
Where is the relaxation time.
- Variables Kvm, Astass, and Bstass are not used in this material law; except for some output in user variables.
- Poisson number "NU" (
) is calculated automatically with bulk modulus K and initial
shear modulus G at time= 0, as:
(2) Where, initial shear modulus
Poisson number "NU" ( ) must be positive and .
