/MAT/LAW50 (VISC_HONEY)
Block Format Keyword This law describes a three dimension orthotropic nonlinear elasto-plastic material, usually used to model honeycomb or foam material.
Nonlinear elastoplastic behavior can be specified for each othrotropic direction and shear as function of strain or volumetric strain. All these degrees of freedom are fully uncoupled. The material is fully compressible. Tension and shear strain-based failure criteria can be specified. This honeycomb material is like material LAW28 except that LAW50 includes strain rate dependency.
/MAT/LAW50/mat_ID/unit_ID or /MAT/VISC_HONEY/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
E11 | E22 | E33 | |||||||
G12 | G23 | G31 | |||||||
asrate |
Iflag1 | |||||||||
fctID11-1 | fctID11-2 | fctID11-3 | fctID11-4 | fctID11-5 | |||||
Fscale11-1 | Fscale11-2 | Fscale11-3 | Fscale11-4 | Fscale11-5 | |||||
fctID22-1 | fctID22-2 | fctID22-3 | fctID22-4 | fctID22-5 | |||||
Fscale22-1 | Fscale22-2 | Fscale22-3 | Fscale22-4 | Fscale22-5 | |||||
fctID33-1 | fctID33-2 | fctID33-3 | fctID33-4 | fctID33-5 | |||||
Fscale33-1 | Fscale33-2 | Fscale33-3 | Fscale33-4 | Fscale33-5 | |||||
Iflag2 | |||||||||
fctID12-1 | fctID12-2 | fctID12-3 | fctID12-4 | fctID12-5 | |||||
Fscale12-1 | Fscale12-2 | Fscale12-3 | Fscale12-4 | Fscale12-5 | |||||
fctID23-1 | fctID23-2 | fctID23-3 | fctID23-4 | fctID23-5 | |||||
Fscale23-1 | Fscale23-2 | Fscale23-3 | Fscale23-4 | Fscale23-5 | |||||
fctID31-1 | fctID31-2 | fctID31-3 | fctID31-4 | fctID31-5 | |||||
Fscale31-1 | Fscale31-2 | Fscale31-3 | Fscale31-4 | Fscale31-5 | |||||
Definition
mat_ID | Material identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material title (Character, maximum 100 characters) |
Initial material
density (Real) |
E11 | Young's modulus in orthotropic direction
1 (Real) |
E22 | Young's modulus in orthotropic direction
2 (Real) |
E33 | Young's modulus in orthotropic direction
3 (Real) |
G12 | Shear modulus in direction
12 (Real) |
G23 | Shear modulus in direction
23 (Real) |
G31 | Shear modulus in direction
31 (Real) |
asrate | Strain rate filtering cutoff
frequency (Real) |
Iflag1 | Strain formulation for yield functions
11, 22, and 33. 6
(Integer) |
Failure plastic strain in direction
11. (Real) |
22. (Real) |
33. (Real) |
fctID11-1 | Identifier of yield stress function
number 1 in direction 11. (Integer) |
fctID11-2 | Identifier of yield stress function
number 2 in direction 11. (Integer) |
fctID11-3 | Identifier of yield stress function
number 3 in direction 11. (Integer) |
fctID11-4 | Identifier of yield stress function
number 4 in direction 11. (Integer) |
fctID11-5 | Identifier of yield stress function
number 5 in direction 11. (Integer) |
Fscale11-1 | Scale factor for yield stress function
number 1 in direction 11, fctID11-1. Default = 1.0 (Real) |
Fscale11-2 | Scale factor for yield stress function
number 2 in direction 11, fctID11-2. Default = 1.0 (Real) |
Fscale11-3 | Scale factor for yield stress function
number 3 in direction 11, fctID11-3. Default = 1.0 (Real) |
Fscale11-4 | Scale factor for yield stress function
number 4 in direction 11, fctID11-4. Default = 1.0 (Real) |
Fscale11-5 | Scale factor for yield stress function
number 5 in direction 11, fctID11-5. Default = 1.0 (Real) |
Strain rate for function number 1 in
direction 11, fctID11-1. (Real) |
Strain rate for function number 2 in
direction 11, fctID11-2. (Real) |
Strain rate for function number 3 in
direction 11, fctID11-3. (Real) |
Strain rate for function number 4 in
direction 11, fctID11-4. (Real) |
Strain rate for function number 5 in
direction 11, fctID11-5. (Real) |
fctID22-1 | Identifier of yield stress function
number 1 in direction 22. (Integer) |
fctID22-2 | Identifier of yield stress function
number 2 in direction 22. (Integer) |
fctID22-3 | Identifier of yield stress function
number 3 in direction 22. (Integer) |
fctID22-4 | Identifier of yield stress function
number 4 in direction 22. (Integer) |
fctID22-5 | Identifier of yield stress function
number 5 in direction 22. (Integer) |
Fscale22-1 | Scale factor for yield stress function
number 1 in direction 22, fctID22-1. Default = 1.0 (Real) |
Fscale22-2 | Scale factor for yield stress function
number 2 in direction 22, fctID22-2. Default = 1.0 (Real) |
Fscale22-3 | Scale factor for yield stress function
number 3 in direction 22, fctID22-3. Default = 1.0 (Real) |
Fscale22-4 | Scale factor for yield stress function
number 4 in direction 22, fctID22-4. Default = 1.0 (Real) |
Fscale22-5 | Scale factor for yield stress function
number 5 in direction 22, fctID22-5. Default = 1.0 (Real) |
direction 22, fctID22-1. (Real) |
direction 22, fctID22-2. (Real) |
direction 22, fctID22-3. (Real) |
direction 22, fctID22-4. (Real) |
direction 22, fctID22-5. (Real) |
fctID33-1 | Identifier of yield stress function
number 1 in direction 33. (Integer) |
fctID33-2 | Identifier of yield stress function
number 2 in direction 33. (Integer) |
fctID33-3 | Identifier of yield stress function
number 3 in direction 33. (Integer) |
fctID33-4 | Identifier of yield stress function
number 4 in direction 33. (Integer) |
fctID33-5 | Identifier of yield stress function
number 5 in direction 33. (Integer) |
Fscale33-1 | Scale factor for yield stress function
number 1 in direction 33, fctID33-1. Default = 1.0 (Real) |
Fscale33-2 | Scale factor for yield stress function
number 2 in direction 33, fctID33-2. Default = 1.0 (Real) |
Fscale33-3 | Scale factor for yield stress function
number 3 in direction 33, fctID33-3 Default = 1.0 (Real) |
Fscale33-4 | Scale factor for yield stress function
number 4 in direction 33, fctID33-4 Default = 1.0 (Real) |
Fscale33-5 | Scale factor for yield stress function
number 5 in direction 33, fctID33-5 Default = 1.0 (Real) |
direction 33, fctID33-1 (Real) |
direction 33, fctID33-2 (Real) |
direction 33, fctID33-3 (Real) |
direction 33, fctID33-4 (Real) |
direction 33, fctID33-5 (Real) |
Iflag2 | Strain formulation for shear yield
functions 12, 23, and 31. 6
(Integer) |
Shear failure plastic strain in
direction 12 (Real) |
direction 23 (Real) |
direction 31 (Real) |
fctID12-1 | Identifier of shear yield stress
function number 1 in direction 12 (Integer) |
fctID12-2 | Identifier of shear yield stress
function number 2 in direction 12 (Integer) |
fctID12-3 | Identifier of shear yield stress
function number 3 in direction 12 (Integer) |
fctID12-4 | Identifier of shear yield stress
function number 4 in direction 12 (Integer) |
fctID12-5 | Identifier of shear yield stress
function number 5 in direction 12 (Integer) |
Fscale12-1 | Scale factor for shear yield stress
function number 1 in direction 12, fctID12-1 Default = 1.0 (Real) |
Fscale12-2 | Scale factor for shear yield stress
function number 2 in direction 12, fctID12-2 Default = 1.0 (Real) |
Fscale12-3 | Scale factor for shear yield stress
function number 3 in direction 12, fctID12-3 Default = 1.0 (Real) |
Fscale12-4 | Scale factor for shear yield stress
function number 4 in direction 12, fctID12-4 Default = 1.0 (Real) |
Fscale12-5 | Scale factor for shear yield stress
function number 5 in direction 12, fctID12-5 Default = 1.0 (Real) |
direction 12, fctID12-1 (Real) |
direction 12, fctID12-2 (Real) |
direction 12, fctID12-3 (Real) |
direction 12, fctID12-4 (Real) |
direction 12, fctID12-5 (Real) |
fctID23-1 | Identifier of shear yield stress
function number 1 in direction 23 (Integer) |
fctID23-2 | Identifier of shear yield stress
function number 2 in direction 23 (Integer) |
fctID23-3 | Identifier of shear yield stress
function number 3 in direction 23 (Integer) |
fctID23-4 | Identifier of shear yield stress
function number 4 in direction 23 (Integer) |
fctID23-5 | Identifier of shear yield stress
function number 5 in direction 23 (Integer) |
Fscale23-1 | Scale factor for shear yield stress
function number 1 in direction 23, fctID23-1 Default = 1.0 (Real) |
Fscale23-2 | Scale factor for shear yield stress
function number 2 in direction 23, fctID23-2 Default = 1.0 (Real) |
Fscale23-3 | Scale factor for shear yield stress
function number 3 in direction 23, fctID23-3 Default = 1.0 (Real) |
Fscale23-4 | Scale factor for shear yield stress
function number 4 in direction 23, fctID23-4 Default = 1.0 (Real) |
Fscale23-5 | Scale factor for shear yield stress
function number 5 in direction 23, fctID23-5 Default = 1.0 (Real) |
direction 23, fctID23-1 (Real) |
direction 23, fctID23-2 (Real) |
direction 23, fctID23-3 (Real) |
direction 23, fctID23-4 (Real) |
direction 23, fctID23-5 (Real) |
fctID31-1 | Identifier of shear yield stress
function number 1 in direction 31 (Integer) |
fctID31-2 | Identifier of shear yield stress
function number 2 in direction 31 (Integer) |
fctID31-3 | Identifier of shear yield stress
function number 3 in direction 31 (Integer) |
fctID31-4 | Identifier of shear yield stress
function number 4 in direction 31 (Integer) |
fctID31-5 | Identifier of shear yield stress
function number 5 in direction 31 (Integer) |
Fscale31-1 | Scale factor for shear yield stress
function number 1 in direction 31, fctID31-1 Default = 1.0 (Real) |
Fscale31-2 | Scale factor for shear yield stress
function number 2 in direction 31, fctID31-2 Default = 1.0 (Real) |
Fscale31-3 | Scale factor for shear yield stress
function number 3 in direction 31, fctID31-3 Default = 1.0 (Real) |
Fscale31-4 | Scale factor for shear yield stress
function number 4 in direction 31, fctID31-4 Default = 1.0 (Real) |
Fscale31-5 | Scale factor for shear yield stress
function number 5 in direction 31, fctID31-5 Default = 1.0 (Real) |
direction 31, fctID31-1 (Real) |
direction 31, fctID31-2 (Real) |
direction 31, fctID31-3 (Real) |
direction 31, fctID31-4 (Real) |
direction 31, fctID31-5 (Real) |
Example (Honeycomb)
#RADIOSS STARTER
/UNIT/1
unit for mat
kg mm ms
#- 2. MATERIALS:
/MAT/LAW50/1/1
Honeycomb material
# RHO_I
2.87E-8
# E11 E22 E33
.1655 .01655 .01655
# G12 G23 G31
.1103 .00552 .1103
# asrate
0
# Iflag1 Eps_max11 Eps_max22 Eps_max33
-1 .1 .2 .2
#fctID11-1 fctID11-2 fctID11-3 fctID11-4 fctID11-5
2 12 13 13 0
# Fscale_11-1 Fscale_11-2 Fscale_11-3 Fscale_11-4 Fscale_11-5
0 0 0 0 0
# Eps_rate_11-1 Eps_rate_11-2 Eps_rate_11-3 Eps_rate_11-4 Eps_rate_11-5
.01 .012 .015 .4 0
#fctID22-1 fctID22-2 fctId22-3 fctID22-4 fctID22-5
3 3 0 0 0
# Fscale_22-1 Fscale_22-2 Fscale_22-3 Fscale_22-4 Fscale_22-5
0 0 0 0 0
# Eps_rate_22-1 Eps_rate_22-2 Eps_rate_22-3 Eps_rate_22-4 Eps_rate_22-5
.01 .4 0 0 0
#fctID33-1 fctID33-2 fctID33-3 fctID33-4 fctnID33-5
3 3 0 0 0
# Fscale_33-1 Fscale_33-2 Fscale_33-3 Fscale_33-4 Fscale_33-5
0 0 0 0 0
# Eps_rate_33-1 Eps_rate_33-2 Eps_rate_33-3 Eps_rate_33-4 Eps_rate_33-5
.01 .4 0 0 0
# Iflag2 Eps_max12 Eps_max23 Eps_max31
-1 0 0 0
#fctID12-1 fctID12-2 fctID12-3 fctID12-4 fctID12-5
4 4 0 0 0
# Fscale_12-1 Fscale_12-2 Fscale_12-3 Fscale_12-4 Fscale_12-5
0 0 0 0 0
# Eps_rate_12-1 Eps_rate_12-2 Eps_rate_12-3 Eps_rate_12-4 Eps_rate_12-5
.01 .4 0 0 0
#fctID23-1 fctID23-2 fctID23-3 fctID23-4 fctID23-5
5 5 0 0 0
# Fscale_23-1 Fscale_23-2 Fscale_23-3 Fscale_23-4 Fscale_23-5
0 0 0 0 0
# Eps_rate_23-1 Eps_rate_23-2 Eps_rate_23-3 Eps_rate_23-4 Eps_rate_23-5
.01 .4 0 0 0
#fctID31-1 fctID31-2 fctID31-3 fctID31-4 fctID31-5
4 4 0 0 0
# Fscale_31-1 Fscale_31-2 Fscale_31-3 Fscale_31-4 Fscale_31-5
0 0 0 0 0
# Eps_rate_31-1 Eps_rate_31-2 Eps_rate_31-3 Eps_rate_31-4 Eps_rate_31-5
.01 .4 0 0 0
/FUNCT/2
Y11_MAIN_BLOCK_STATIC
# X Y
-1 1.2E-6
-.15 1.2E-6
-.1 .0012
0 3.42E-4
.8 3.42E-4
.85 7E-4
.86 9.3E-4
1 .00342
/FUNCT/3
Y22_Y33_MAIN_BLOCK
# X Y
-1 4.5E-4
-.22 4.5E-4
-.14 2.5E-4
-.12 6.84E-5
0 6.84E-5
.8 6.84E-5
.85 1.4E-4
.86 1.86E-4
1 6.84E-4
/FUNCT/4
Y12_13_MAIN_BLOCK
# X Y
-1 2E-6
-.35 2E-6
-.3 2E-4
0 2E-4
.3 2E-4
.35 2E-6
1 2E-6
/FUNCT/5
Y23_MAIN_BLOCK
# X Y
-1 2E-4
-.3 2E-4
-.25 2E-5
0 2E-5
.25 2E-5
.3 2E-4
1 2E-4
/FUNCT/12
Y11_MAIN_BLOCK_DYNAMIC
# X Y
-1 1.2E-6
-.15 1.2E-6
-.1 .0012
0 3.42E-4
.5 3.65E-4
.7 4.8E-4
.8 6E-4
.85 7E-4
.86 9.3E-4
1 .00342
/FUNCT/13
Y11_MAIN_BLOCK_DYNAMIC-2
# X Y
-1 1.2E-6
-.15 1.2E-6
-.1 .0012
0 3.42E-4
.5 3.65E-4
.7 5.8E-4
.8 7E-4
.85 8E-4
.86 9.3E-4
1 .00342
#ENDDATA
/END
- This material can be used with the following elements: hexahedral, 4 node tetra, 10 node tetra, and thick shells.
- This material is based on material /MAT/LAW28 (HONEYCOMB) + strain rate dependency.
- Material orthotropic
coordinate system for each element (directions 1, 2, and 3) are specified in the property
card /PROP/TYPE6 either through a given skew system or related to
element coordinate system.
Figure 1. - All element degrees of
Elastic case example:
- For each tension/compression
and shear direction, the true stress as function of a true volumetric strain
, or a true strain
can be specified.Sign conventions for strain are:
Figure 2.The stress values should always be positive. The following sign conventions for strain are used:Strain Definition Compression Tension Volumetric strain (Iflag1 =0) + - Strain (Iflag1 =1) - + Strain (Iflag1 =-1) + - - For large strain formulations
defined in the property using Ismstr > 1:
(1) For small strains defined in the property using Ismstr = 1:(2) Where, is the initial length.
- When switching from a volumetric strain formulation to a strain formulation, Iflag1 = -1 or Iflag2 = -1 allows the same function definition to be retained.
- If one of the tension strain or shear strain failures is reached, the element is deleted.
