/MAT/LAW82
Block Format Keyword This keyword defines the Ogden material. This law is compatible with solid and shell elements. In general it is used to model polymers and elastomers.
/MAT/LAW82/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
N | v | ||||||||
. . . N values of (five per line) | |||||||||
. . . N values of α (five per line) | |||||||||
D1 | D2 | D3 | |||||||
. . . N values of D (five per line) |
Definition
mat_ID | Material
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material
Initial
density (Real) |
N | Order of the Ogden
model. (Integer, maximum 10 digits) |
v | Poisson's ratio Default value depends on D1 input. 2 (Real) |
ith Parameter (i
= 1,N). (Real) |
ith Parameter
(i =
1,N). (Real) |
Di | ith Parameter
(i =
1,N). (Real) |
Example (Rubber)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/LAW82/1/1
LAW82 RUBBER
# RHO_I
1E-9 0
# N Nu
2 .495
# Mu_i
2 1
# Alpha_i
2 -2
# D_i
0 0
#ENDDATA
/END
Example (Hyper-elastic Rubber)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/LAW82/1/1
Rubber
# RHO_I
2E-9
# N Nu
3 0
# Mu_i
1.061898 .0578289 .0159176
# Alpha_i
.428246 5.71269 -4.59726
# D_i
1E-4 0 0
#ENDDATA
/END
- The strain energy density
is computed using the following
equation:
(1) with and J = 1 2 3
where, is the ith principal stretch.
- The initial shear
modulus:
(2) The Bulk Modulus is calculated as , based on the following rules:- If , then D1 should be entered entered.
- If
, D1
input is ignored and will be recalculated and output in the Starter
output using the formula:
(3) - If and D1 = 0, then a default value of is used and D1 is calculated using Equation 3
- To get a material without Poisson ratio effect, v should be defined with a small value (1e-10).
- Further explanation about this law can be found in "Non-Linear Elastic Deformations", by R.W Ogden, Ellis Horwood, 1984.
