/MAT/LAW84
Block Format Keyword Swift-Voce elastoplastic law with Johnson-Cook strain rate hardening and temperature softening. This law allows modeling a quadratic non-associated flow rule.
/MAT/LAW84/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
E | |||||||||
P12 | P22 | P33 | Q | B | |||||
G12 | G22 | G33 | K0 | ||||||
A | n | C | |||||||
Cp | Tini | Tref | Tmelt | ||||||
m |
Definition
mat_ID | Material
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material
Initial
density (Real) |
E | Young's
modulus (Real) |
Poisson's
ratio (Real) |
P12 | Yield parameter Default = -0.5 (Real) |
P22 | Yield parameter Default = 1.0 (Real) |
P33 | Yield parameter Default = 3.0 (Real) |
G12 | Flow rule
parameter Default = P12 (Real) |
G22 | Flow rule
parameter Default = P22 (Real) |
G33 | Flow rule
parameter Default = P33 (Real) |
Q | Voce hardening
coefficient (Real) |
B | Voce plastic strain
coefficient Default = 0.0 (Real) |
K0 | Voce
parameter (Real) |
Yield weighting
coefficient.
A | Swift hardening
coefficient. (Real) |
n | Swift hardening
exponent. Default = 1.0 (Real) |
Swift hardening
parameter. Default = 0.00 (Real) |
C | Strain rate
coefficient.
Reference strain
rate. Default = 1030, no strain rate effect (Real) |
Taylor-Quinney coefficient
quantifies the fraction of plastic work converted to
heat. (Real) |
Cp | Specific
heat. (Real) |
Tini | Initial temperature used
in initialization when time=0. (Real) |
Tref | Reference
temperature. (Real) |
Tmelt | Melting
m | Temperature
exponent. (Real) |
Strain rate optimization
parameter for temperature dependency. (Real) |
Example (Metal)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/LAW84/1/1
Swift-voce (metal)
# Rho_i
8E-9
# E Nu
206000 .3
# P12 P22 P33 Q B
-.5 1 3 524 25
# G12 G22 G33 K0 ALPHA
-.5 1 3 100 .5
# A EPS0 n C EPSDOT
1000 .00128 .2 .014 .0011
# ETA CP Tini Tref Tmelt
.9 42000000000 293 293 1700
# m EPSDOTA
.921 1.379
#ENDDATA
/END
- Yield stress is computed using an analytic
expression with a combination of both Swift and Voce models, the strain rate
dependency and temperature dependency following Johnson-Cook
law.
(1) - The effective stress is computed
as:
(2) - The plastic non-associated flow rule is computed as:
(3) Where,(4) - Temperature is updated using:
(5) Where,
