*MAT_S05 (DAMPER_NONLINEAR_VISCOUS)
LS-DYNA Input Interface KeywordDefines a nonlinear damper spring material.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_S05 or *MAT_DAMPER_NONLINEAR_VISCOUS
mat_ID LCD
Definition
mat_ID Material identifier.
(Integer)
LCD Curve identifier for force versus elongation velocity or moment versus rotational velocity.
(Real)
  1. This keyword maps to /MAT/LAW108 (SPR_GENE).
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
