/MONVOL/PRES
Block Format Keyword Describes the pressure load curve monitored volume type.
/MONVOL/PRES/monvol_ID/unit_ID | |||||||||
monvol_title | |||||||||
surf_IDex | |||||||||
Ascalet | |||||||||
fct_ID | Fscale | Itypfun |
Definition
monvol_ID | Monitored volume
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
monvol_title | Monitored volume
title. (Character, maximum 100 characters) |
surf_IDex | External surface
identifier. (Integer) |
Ascalet | Abscissa scale factor for
time based functions. 4 (Real) |
fct_ID | Load curve identifier for
relative pressure. If Itypfun=0, the function defines If Itypfun=1, the function defines If Itypfun=2, the function defines If Itypfun=3, the function defines (Integer) |
Fscale | Load curve scale factor
for relative pressure. 4 Default = 1.0 (Real) |
Itypfun | Flag type of relative
pressure function defined in fct_ID.
(Integer) |
- The relative pressure is defined as, Prel = pressure inside of monitored volume - atmospheric pressure.
- surf_IDex must be defined using segments associated with 4- or 3-nodes shell elements (possibly void elements) and not with /SURF/SEG.
- The volume must be closed and the normals must be oriented outwards.
- Abscissa scale factors are used to
transform abscissa units in airbag functions, for example:
(1) Where, is time.(2) Where, is relative pressure.
