/NODE
Block Format Keyword Defines the coordinate of node, which is fundamental unit of graphic in structure.
/NODE/unit_ID | |||||||||
node_ID | Xc | Yc | Zc |
Definition
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
node_ID | Node
identifier. (Integer) |
Xc | X
coordinate. (Real) |
Yc | Y
Zc | Z
- Nodes may be defined with more than one block.
