*NODE_TRANSFORM
LS-DYNA Input Interface KeywordDefines a node coordinate transformation applied on a set of nodes.
(1) (2) (3) (4) (5) (6) (7) (8)
*NODE_TRANSFORM
TRA_ID Set_ID
Definition
TRA_ID Transformation ID (*DEFINE_TRANSFORMATION).
(Integer)
Set_ID Node set ID.
(Integer)
  1. This keyword maps to /TRANSFORM cards.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
