/PROP/INJECT2
Block Format Keyword Describes molar fraction injected for each constituent gas and total mass injected.
/PROP/INJECT2/inject_ID/unit_ID
inject_title
Ngases Iflow
fct_IDM fct_IDT FscaleM FscaleT AscaleT
Define mixture data for Ngases gases: define molar fraction for constant gas mixture or function for gas mixture variable with time
mat_ID1   Molar_Fraction1 f c t _ I D m f 1
mat_ID2   Molar_Fraction2 f c t _ I D m f 2
etc
mat_IDN   Molar_FractionN f c t _ I D m f N
Definition
inject_ID Injector identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
inject_title Injector title.
Ngases Number of gases.
(Integer, 1 ≤ Ngases ≥ 100)
Iflow Mass versus time function input type flag.
= 0
Mass is input.
= 1
Mass flow is input - the input scale factor on time is also applied to mass flow.
(Integer)
fct_IDM Mass of injected gas versus time function identifier.
(Integer)
fct_IDT Temperature of injected gas versus time function identifier.
(Integer)
FscaleM Mass function scale factor.
Default = 1.0 (Real)
[ kg ] or [ kg s ]
FscaleT Temperature function scale factor.
[ K ]
AscaleT Abscissa scale factor for time based functions. 1
[ s ]
mat_IDi Material identifier that identifies the gas (i=1,2...N).
(Integer)
Molar_Fractioni Molar fraction of injected gas (i=1,2...N).
(Real)
f c t _ I D m f i Molar fraction of injected gas versus time function identifier (i=1,2...N).
(Integer)
  1. The sum of Molar_Fraction must be 1.0 at any given time.
  2. The f c t _ I D m f i are function identifiers used to define variable molar fraction with time. The function must be defined with the same time abscissa. If f c t _ I D m f i > 0, Molar_Fraction is not used.
