/PROP/TYPE2 (TRUSS)
Block Format Keyword This property is used to define the truss property set.
/PROP/TYPE2/prop_ID/unit_ID or /PROP/TRUSS/prop_ID/unit_ID
prop_title
Area Gapini
Definition
prop_ID Property identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
prop_title Property title
Area Initial cross section
(Real)
[ m 2 ]
Gapini Initial gap
Default = 0 (Real)
[ m ]
  1. For truss elements, if ν 0 the cross section variation is computed as:(1)
    A r e a t = A r e a t d t ( 1 + v ε ˙ x d t ) 2
    Where, υ is the Poisson's ratio given in the material law.
  2. The truss is activated only if:(2)
    L e n g t h t r u s s c u r r e n t < L e n g t h t r u s s i n i t i a l G a p i n i
    The current distance between truss nodes is smaller than the initial length minus Gapini.
  3. Gapini should be Gapini > 0. Negative Gapini. will be treated as 0. The truss will not be activated in tensile.
